LG Tribute Touchscreen Replacement
  1. LG Tribute Touchscreen Replacement, Battery: step 1, image 1 of 2 LG Tribute Touchscreen Replacement, Battery: step 1, image 2 of 2
    • Use the plastic opening tool to pry off the back cover.
  2. LG Tribute Touchscreen Replacement: step 2, image 1 of 1
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
  3. LG Tribute Touchscreen Replacement, Mid-panel: step 3, image 1 of 2 LG Tribute Touchscreen Replacement, Mid-panel: step 3, image 2 of 2
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
  4. LG Tribute Touchscreen Replacement: step 4, image 1 of 2 LG Tribute Touchscreen Replacement: step 4, image 2 of 2
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
  5. LG Tribute Touchscreen Replacement, Motherboard: step 5, image 1 of 1
    • Use a plastic opening tool to disconnect the touchscreen from the motherboard.
    • The motherboard will be completely free from the front panel after this step.
  6. LG Tribute Touchscreen Replacement, Touchscreen: step 6, image 1 of 3 LG Tribute Touchscreen Replacement, Touchscreen: step 6, image 2 of 3 LG Tribute Touchscreen Replacement, Touchscreen: step 6, image 3 of 3
    • Use a thin piece of plastic to carefully peel the frame away from the touchscreen glass.
    • When the frame is completely free, remove all of the glue.
    • When removing the glue, be sure the speaker grill and LED light spacer do not dislodge.
12 other people completed this guide.
4 Comments
thank you for all ypu work at web site
salah dholman - Reply
Can you peel away lens without taking apart ?
mikeknapik1 - Reply
Must I remove the motherboard to replace the front cover with the glass?
Deb Schell - Reply
I messed up the speaker is there a way to replace or fix it
bigestbabybratt - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 16,124
