LG Tribute Motherboard Replacement
  1. LG Tribute Motherboard Replacement, Battery: step 1, image 1 of 2 LG Tribute Motherboard Replacement, Battery: step 1, image 2 of 2
    • Use the plastic opening tool to pry off the back cover.
  2. LG Tribute Motherboard Replacement: step 2, image 1 of 1
    • Lift the battery out of place.
    • When replacing the battery, the (+) and (-) symbols must match up with the phone's charging nodes.
  3. LG Tribute Motherboard Replacement, Mid-panel: step 3, image 1 of 2 LG Tribute Motherboard Replacement, Mid-panel: step 3, image 2 of 2
    • Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
  4. LG Tribute Motherboard Replacement: step 4, image 1 of 2 LG Tribute Motherboard Replacement: step 4, image 2 of 2
    • Use a plastic opening tool to loosen the tabs around the edge of the phone.
    • Inserting a thin piece of plastic will help prevent opened tabs from locking back into place.
    • This step can be frustrating, but requires patience. Avoid the temptation to pry the panel loose. Using excessive force may break the delicate tabs.
  5. LG Tribute Motherboard Replacement, Motherboard: step 5, image 1 of 1
    • Use a plastic opening tool to disconnect the touchscreen from the motherboard.
    • The motherboard will be completely free from the front panel after this step.
  6. LG Tribute Motherboard Replacement, Motherboard: step 6, image 1 of 3 LG Tribute Motherboard Replacement, Motherboard: step 6, image 2 of 3 LG Tribute Motherboard Replacement, Motherboard: step 6, image 3 of 3
    • Remove SIM card by sliding it out of its housing.
    • Remove the front-facing camera using a plastic opening tool.
    • Remove rear-facing camera using a plastic opening tool.
    • Connect these three components to the new motherboard.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 14
All Time: 3,862
