Shop the Holiday Gift Guide
LG Treasure Rear Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
44
All Time:
684
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will explain how to replace the rear camera on the LG Treasure.
Tools
    1. LG Treasure Rear Camera Replacement, Battery: step 1, image 1 of 2 LG Treasure Rear Camera Replacement, Battery: step 1, image 2 of 2
      • Make sure the LG Treasure is turned off.
      • Pull off the back cover from the phone using the groove on the bottom right side.
      Ask FixBot
    2. LG Treasure Rear Camera Replacement: step 2, image 1 of 1
      • Remove the battery from the phone by lifting up on the bottom end of the battery.
      Ask FixBot
    1. LG Treasure Rear Camera Replacement, Rear Camera: step 3, image 1 of 2 LG Treasure Rear Camera Replacement, Rear Camera: step 3, image 2 of 2
      • Remove all 9 of the 3 mm Phillips #000 screws from the digitizer.
      • Work your way around the edge of the phone, gently prying the digitizer off the phone.
      Ask FixBot
    2. LG Treasure Rear Camera Replacement: step 4, image 1 of 2 LG Treasure Rear Camera Replacement: step 4, image 2 of 2
      • Pull up on the gold film-like connector which is to the left side of camera. Once you have pulled the connector loose you can then gently lift the rear camera out of the phone.
      Ask FixBot
2 other people completed this guide.
Author
with
david amirahmadi
594 Reputation
5 Guides authored
UW Stout, Team S8-G5, Ogden Spring 2018 Member of UW Stout, Team S8-G5, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 44
All Time: 684
