LG Treasure Loudspeaker Replacement
    1. LG Treasure Loudspeaker Replacement, Battery: step 1, image 1 of 2 LG Treasure Loudspeaker Replacement, Battery: step 1, image 2 of 2
      • Make sure the LG Treasure is turned off.
      • Pull off the back cover from the phone using the groove on the bottom right side.
      Ask FixBot
    2. LG Treasure Loudspeaker Replacement: step 2, image 1 of 1
      • Remove the battery from the phone by lifting up on the bottom end of the battery.
      Ask FixBot
    1. LG Treasure Loudspeaker Replacement, Loudspeaker: step 3, image 1 of 2 LG Treasure Loudspeaker Replacement, Loudspeaker: step 3, image 2 of 2
      • Remove all 9 of the 3mm Phillips #000 screws from the digitizer.
      • Remove the digitizer like you did the back cover by working your way around the edge peeling it up.
      Ask FixBot
    2. LG Treasure Loudspeaker Replacement: step 4, image 1 of 2 LG Treasure Loudspeaker Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use the tweezers to lift the loudspeaker out of place.
      Ask FixBot
david amirahmadi
594 Reputation
5 Guides authored
UW Stout, Team S8-G5, Ogden Spring 2018 Member of UW Stout, Team S8-G5, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 49
All Time: 529
