LG Treasure Rear Camera Replacement
  1. LG Treasure Rear Camera Replacement, Battery: step 1, image 1 of 2 LG Treasure Rear Camera Replacement, Battery: step 1, image 2 of 2
    • Make sure the LG Treasure is turned off.
    • Pull off the back cover from the phone using the groove on the bottom right side.
  2. LG Treasure Rear Camera Replacement: step 2, image 1 of 1
    • Remove the battery from the phone by lifting up on the bottom end of the battery.
  3. LG Treasure Rear Camera Replacement, Rear Camera: step 3, image 1 of 2 LG Treasure Rear Camera Replacement, Rear Camera: step 3, image 2 of 2
    • Remove all 9 of the 3 mm Phillips #000 screws from the digitizer.
    • Work your way around the edge of the phone, gently prying the digitizer off the phone.
  4. LG Treasure Rear Camera Replacement: step 4, image 1 of 2 LG Treasure Rear Camera Replacement: step 4, image 2 of 2
    • Pull up on the gold film-like connector which is to the left side of camera. Once you have pulled the connector loose you can then gently lift the rear camera out of the phone.
2 other people completed this guide.
david amirahmadi
585 Reputation
5 Guides authored
UW Stout, Team S8-G5, Ogden Spring 2018 Member of UW Stout, Team S8-G5, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G5
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 9
All Time: 214
