LG Treasure Auxiliary Port Replacement
  1. LG Treasure Auxiliary Port Replacement, Battery: step 1, image 1 of 2 LG Treasure Auxiliary Port Replacement, Battery: step 1, image 2 of 2
    • Make sure the LG Treasure is turned off.
    • Pull off the back cover from the phone using the groove on the bottom right side.
  2. LG Treasure Auxiliary Port Replacement: step 2, image 1 of 1
    • Remove the battery from the phone by lifting up on the bottom end of the battery.
  3. LG Treasure Auxiliary Port Replacement, Auxiliary Port: step 3, image 1 of 2 LG Treasure Auxiliary Port Replacement, Auxiliary Port: step 3, image 2 of 2
    • Remove all 9 of the 3mm Phillips #000 screws from the digitizer.
    • Work your way around the edge of the phone, gently prying the digitizer off the phone.
  4. LG Treasure Auxiliary Port Replacement: step 4, image 1 of 3 LG Treasure Auxiliary Port Replacement: step 4, image 2 of 3 LG Treasure Auxiliary Port Replacement: step 4, image 3 of 3
    • Insert your finger nail into the groove under the Auxiliary Port and pry the Auxiliary Port out.
david amirahmadi
585 Reputation
5 Guides authored
UW Stout, Team S8-G5, Ogden Spring 2018 Member of UW Stout, Team S8-G5, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G5
3 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 322
