LG Tone Infinim HBS-910 Battery Replacement
  1. LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: step 1, image 1 of 3 LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: step 1, image 2 of 3 LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: step 1, image 3 of 3
    • Battery is on right side of headset.
    • First remove rubber cover on the right side of the headset to uncover the hidden screw.
    • Remove screw using Philips PH00 screwdriver.
  2. LG Tone Infinim HBS-910 Battery Replacement, Disassemble right side.: step 2, image 1 of 2 LG Tone Infinim HBS-910 Battery Replacement, Disassemble right side.: step 2, image 2 of 2
    • Use a guitar pick or any opening tool to pry open the right side.
  3. LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: step 3, image 1 of 3 LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: step 3, image 2 of 3 LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: step 3, image 3 of 3
    • Once you have opened the right side up until the speaker end, there will be a hidden screw that needs to be unscrewed before the right side can be completely disassembled.
    • Pry open the speaker back housing with a guitar pick or any opening tool as shown in the picture.
    • Once the speaker back housing is lifted, you will see the screw.
    • Remove the screw and the whole right side will be disassembled.
    Search f9r replacement rechargeable hearing ampliflire batteries
    wayneharnon74graduate - Reply
  4. LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: step 4, image 1 of 3 LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: step 4, image 2 of 3 LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: step 4, image 3 of 3
    • Use a non-metal tool to lift the battery out of place so it will be easy to desolder.
    • Remember the red wire is positive(+) and the black wire is negative(-).
13 other people completed this guide.
Faizan Naveed
3,294 Reputation
8 Guides authored
Mobile Device Repair Factory Member of Mobile Device Repair Factory
Business
1 Member
16 Guides authored
2 Comments
Battery model and amps
honda kung - Reply
Hello budy!
Tanks for the guide, i was going crazy looking for that hidden screw!
You might be able to help me. Would you know what i must look for a malfunctioning earbud? My right one suddenly died and im hoping the cord isn't broken and its just some loose weld.
Rafael Zerbini - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 27
All Time: 11,269
