Introduction
This repair is to replace the screen on an LG Rebel. One might need to do this if the screen is cracked or unresponsive. If your screen is cracked be careful not to scratch yourself on the glass.
Place the plastic opening tool into the indent on the side of the phone and lift the back off the device.
Put the plastic opening tool in at a downward angle and push it up so that the back pops off.
Using either your finger or the spudger, gently lift the metal clasps until they are no longer connected to the back of the phone.
Using the metal spudger, push gently under the edge of the screen. You will hear the sound of the screen disconnecting from the glue.
Run the metal spudger around the entire perimeter of the phone , making sure to fully disconnect it from the glue.
Place suction cup on the screen.
Gently pull the screen up until it is completely disconnected from the phone.
