LG Realm Rear Facing Camera Replacement
    1. LG Realm Rear Facing Camera Replacement, Battery: step 1, image 1 of 2 LG Realm Rear Facing Camera Replacement, Battery: step 1, image 2 of 2
      • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
      • Use nail to loosen case on all four sides. Once loose, remove back case.
      Ask FixBot
    2. LG Realm Rear Facing Camera Replacement: step 2, image 1 of 1
      • Insert thumbnail into tab below battery.
      • Pull away from phone and remove.
      Ask FixBot
    1. LG Realm Rear Facing Camera Replacement, Plastic Midframe: step 3, image 1 of 2 LG Realm Rear Facing Camera Replacement, Plastic Midframe: step 3, image 2 of 2
      • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
      Ask FixBot
    2. LG Realm Rear Facing Camera Replacement: step 4, image 1 of 1
      • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
      Ask FixBot
    1. LG Realm Rear Facing Camera Replacement, Rear Facing Camera: step 5, image 1 of 1
      • Locate the rear facing camera.
      • Using the plastic opening tool, pry apart the cable from where it connects to the phone.
      Ask FixBot
    2. LG Realm Rear Facing Camera Replacement: step 6, image 1 of 1
      • After removing the ribbon cable, the camera should be easy to remove with your fingers. Remove the rear facing camera.
      Ask FixBot
3 other people completed this guide.
Emily Palmer
326 Reputation
1 Guide authored
Marist, Team 1-5, Laflen Spring 2016 Member of Marist, Team 1-5, Laflen Spring 2016
MARS-LAFLEN-S16S1G5
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 31
All Time: 588
