LG Phoenix 2 Power and volume buttons Replacement
  1. LG Phoenix 2 Power and volume buttons Replacement, Battery: step 1, image 1 of 3 LG Phoenix 2 Power and volume buttons Replacement, Battery: step 1, image 2 of 3 LG Phoenix 2 Power and volume buttons Replacement, Battery: step 1, image 3 of 3
    • Place a fingernail in the notch at the bottom edge of the phone.
    • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
  2. LG Phoenix 2 Power and volume buttons Replacement: step 2, image 1 of 3 LG Phoenix 2 Power and volume buttons Replacement: step 2, image 2 of 3 LG Phoenix 2 Power and volume buttons Replacement: step 2, image 3 of 3
    • Place a fingernail in the notch at the bottom edge of the battery.
    • Pull the battery out.
  3. LG Phoenix 2 Power and volume buttons Replacement, Power and volume buttons: step 3, image 1 of 2 LG Phoenix 2 Power and volume buttons Replacement, Power and volume buttons: step 3, image 2 of 2
    • Locate the SIM card in the top right corner on the back of the phone.
    • Remove the SIM card by pushing it with your thumb from left to right.
  4. LG Phoenix 2 Power and volume buttons Replacement: step 4, image 1 of 3 LG Phoenix 2 Power and volume buttons Replacement: step 4, image 2 of 3 LG Phoenix 2 Power and volume buttons Replacement: step 4, image 3 of 3
    • Remove all 9 screws on the back by using a Phillips head #J00 screwdriver.
    • To remove the screws rotate them counterclockwise.
  5. LG Phoenix 2 Power and volume buttons Replacement: step 5, image 1 of 3 LG Phoenix 2 Power and volume buttons Replacement: step 5, image 2 of 3 LG Phoenix 2 Power and volume buttons Replacement: step 5, image 3 of 3
    • Insert a plastic opening tool in the split at the bottom of the phone (between the bottom shield and the rest of the phone).
    • Pry the bottom shield to separate it from the phone.
    • Once it is loose you should be able to remove it with your hand.
  6. LG Phoenix 2 Power and volume buttons Replacement: step 6, image 1 of 3 LG Phoenix 2 Power and volume buttons Replacement: step 6, image 2 of 3 LG Phoenix 2 Power and volume buttons Replacement: step 6, image 3 of 3
    • Insert the flat end of the Spudger between the screen and the chromed frame.
    • Once inserted, run the Spudger along the frame to separate the front part of the phone from the back shield.
  7. LG Phoenix 2 Power and volume buttons Replacement: step 7, image 1 of 3 LG Phoenix 2 Power and volume buttons Replacement: step 7, image 2 of 3 LG Phoenix 2 Power and volume buttons Replacement: step 7, image 3 of 3
    • The buttons are attached with adhesive to both sides of the back shield. To separate the orange cables insert a metallic Spudger underneath and gently pull up.
    • Once the orange part is loose move to the next step.
  8. LG Phoenix 2 Power and volume buttons Replacement: step 8, image 1 of 3 LG Phoenix 2 Power and volume buttons Replacement: step 8, image 2 of 3 LG Phoenix 2 Power and volume buttons Replacement: step 8, image 3 of 3
    • Remove the buttons frame on the back side the shield, by inserting a plastic opening tool underneath the frame.
  9. LG Phoenix 2 Power and volume buttons Replacement: step 9, image 1 of 3 LG Phoenix 2 Power and volume buttons Replacement: step 9, image 2 of 3 LG Phoenix 2 Power and volume buttons Replacement: step 9, image 3 of 3
    • The buttons are attached with adhesive. To separate them from the shield insert a metallic Spudger underneath and gently pull up.
    • Once the part is loose you should be able to pass the backside orange cables through the hole.
Esteban Ruibal
702 Reputation
5 Guides authored
USF Tampa, Team S2-G2, Eyestone Spring 2018 Member of USF Tampa, Team S2-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S2G2
4 Members
10 Guides authored
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 9
All Time: 457
