LG Optimus L7 P705 Home Button Replacement
  1. LG Optimus L7 P705 Home Button Replacement, Home Button: step 1, image 1 of 2 LG Optimus L7 P705 Home Button Replacement, Home Button: step 1, image 2 of 2
    • Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
    • Remove the battery and SIM card.
  2. LG Optimus L7 P705 Home Button Replacement: step 2, image 1 of 1
    • Remove the twelve screws using the Phillips 000 screwdriver.
  3. LG Optimus L7 P705 Home Button Replacement: step 3, image 1 of 1
    • Remove bottom plate where the charger port is located.
  4. LG Optimus L7 P705 Home Button Replacement: step 4, image 1 of 2 LG Optimus L7 P705 Home Button Replacement: step 4, image 2 of 2
    • Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
  5. LG Optimus L7 P705 Home Button Replacement: step 5, image 1 of 1
    • Flip over to the face of the device.
    • Lift off the glass screen (display).
  6. LG Optimus L7 P705 Home Button Replacement: step 6, image 1 of 1
    • Remove the home screen button. Replace as needed.
Bruna
525 Reputation
4 Guides authored
USF Tampa, Team 9-1, Leahy Fall 2014 Member of USF Tampa, Team 9-1, Leahy Fall 2014
USFT-LEAHY-F14S9G1
3 Members
5 Guides authored
One Comment
in the step 2, one red ring is in the wrong position.
The ring in the midle at the left side is in the center of the telephone
Tiago - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 11
All Time: 1,812
