Installing LG LX150 Screen
  1. Installing LG LX150 Screen, Front Cover: step 1, image 1 of 3 Installing LG LX150 Screen, Front Cover: step 1, image 2 of 3 Installing LG LX150 Screen, Front Cover: step 1, image 3 of 3
    • Use the spudger to pry out the indicated rubber squares.
    • Use the #0 Phillips screwdriver to take out the revealed screws.
  2. Installing LG LX150 Screen: step 2, image 1 of 3 Installing LG LX150 Screen: step 2, image 2 of 3 Installing LG LX150 Screen: step 2, image 3 of 3
    • Carefully lodge the spudger between the face plate and the hinge mechanism.
    • Gently pry the face plate until it releases from place holders.
  3. Installing LG LX150 Screen, Screen: step 3, image 1 of 2 Installing LG LX150 Screen, Screen: step 3, image 2 of 2
    • Apply even amounts of force upon removing screen, otherwise cracking may occur.
    • Gently loosen the screen from its adhesive by pressing around the screen's rear perimeter with a spudger. Place upward pressure in crevices between face plate and screen.
    • Carefully use both thumbs and apply pressure to the back of the screen to pop out.
Tye Barba
88 Reputation
2 Guides authored
Cal Poly, Team 10-44, Garner Spring 2010 Member of Cal Poly, Team 10-44, Garner Spring 2010
CPSU-GARNER-S10S10G44
4 Members
18 Guides authored
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 14
All Time: 1,357
