LG LRFCS25D3 Water Filter Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
12
Past 30 Days:
69
All Time:
145
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide shows you how to replace the water filter in an LG Refrigerator LRFCS25D3. Replacing the water filter every six months, or as recommended by the manufacturer, helps improve the taste and quality of your drinking water and ice while maintaining proper water flow. A worn or clogged filter can reduce water pressure and allow impurities to remain in the water. This replacement is quick, requires no tools, and can be completed in just a few minutes.
Parts
    1. LG LRFCS25D3 Water Filter Replacement, Water Filter: step 1, image 1 of 1
      • Open the refrigerator door and locate the water filter at the top inside of the refrigerator.
      • Clear the area below the water filter to catch any water that may drip during removal.
      Ask FixBot
    2. LG LRFCS25D3 Water Filter Replacement: step 2, image 1 of 1
      • Squeeze both sides of the water filter cover labeled "Push" until the cover clicks open.
      • Lower the cover on its hinges until it is hanging still.
      Ask FixBot
    3. LG LRFCS25D3 Water Filter Replacement: step 3, image 1 of 1
      • Remove the old water filter by pushing it in and twisting it to the left until it clicks free.
      Ask FixBot
    4. LG LRFCS25D3 Water Filter Replacement: step 4, image 1 of 1
      • Use a replacement water filter that is compatible with your LG refrigerator model.
      Ask FixBot
    5. LG LRFCS25D3 Water Filter Replacement: step 5, image 1 of 1
      • Align the new filter with the opening. Push it in, then turn it clockwise until it locks into place.
      Ask FixBot
    6. LG LRFCS25D3 Water Filter Replacement: step 6, image 1 of 1
      • Push the cover up until it clicks closed.
      Ask FixBot
    7. LG LRFCS25D3 Water Filter Replacement: step 7, image 1 of 1
      • Wipe up any water that dripped during the replacement.
      Ask FixBot
    8. LG LRFCS25D3 Water Filter Replacement: step 8, image 1 of 1
      • Dispense about half a gallon of water to flush the new filter and remove trapped air.
      Ask FixBot
Your water filter is now replaced and is generally replaced every 6 months but can vary by model.
Phoenix Radabaugh
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 69
All Time: 145
