Introduction
This guide will help you replace the inner LCD screen if broken or in need of repair.
Flip open the phone and locate the four screw covers designated by the red circles in the photo.
Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together. The tabs are highlighted by red squares in the third picture.
Carefully lift the LCD and peel it from the gold ribbon. The sticky connection runs all the way around the LCD.
Flip the screen over so that you can see the outer LCD and the circuit board.
Insert spudger in the bottom right corner.
Lift up and move the spudger across the bottom.
Use the pointy side of the spudger to peel off the interior tape.
Flip the assembly over and peel the circuit board from the screen.
