Introduction
This guide will help you replace the camera in the phone.
Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
Flip the screen over so that you can see the outer LCD screen and the circuit board.
Insert spudger in the bottom right corner.
Lift up and move the spudger across the bottom.
Use the pointy side of the spudger to peel off the interior tape.
Flip the assembly over and peel the circuit board from the screen.
Carefully slide the spudger behind the main ribbon in order to separate it from the inside cover of the phone.
Use a spudger to pop off the camera ribbon from the main ribbon. The camera component should separate entirely.
