LG G8 ThinQ Front Cameras Replacement
  1. LG G8 ThinQ Front Cameras Replacement, SIM Card Tray: step 1, image 1 of 3 LG G8 ThinQ Front Cameras Replacement, SIM Card Tray: step 1, image 2 of 3 LG G8 ThinQ Front Cameras Replacement, SIM Card Tray: step 1, image 3 of 3
    • Unplug and power off your phone before you begin.
    • Insert the SIM card eject tool into the pinhole in the lower right side of the phone.
    • Remove the SIM card and tray.
  2. LG G8 ThinQ Front Cameras Replacement, Back Panel: step 2, image 1 of 3 LG G8 ThinQ Front Cameras Replacement, Back Panel: step 2, image 2 of 3 LG G8 ThinQ Front Cameras Replacement, Back Panel: step 2, image 3 of 3
    • Place the phone so that the screen is facing down.
    • Insert opening cards between the back panel and frame of the phone to loosen the clips and adhesive.
    • Using equal pressure, carefully pry the back panel away from the phone.
    • Once enough space has been created, use an opening tool to completely separate the back panel from the phone.
  3. LG G8 ThinQ Front Cameras Replacement, Midframe: step 3, image 1 of 3 LG G8 ThinQ Front Cameras Replacement, Midframe: step 3, image 2 of 3 LG G8 ThinQ Front Cameras Replacement, Midframe: step 3, image 3 of 3
    • Remove all 14 screws from the midframe using a Phillips #000 screwdriver.
    • Work an opening tool around the perimeter of the midframe to pry and remove it from the phone.
  4. LG G8 ThinQ Front Cameras Replacement, Front Cameras: step 4, image 1 of 2 LG G8 ThinQ Front Cameras Replacement, Front Cameras: step 4, image 2 of 2
    • Using an opening tool, carefully disconnect the ribbon cables from both cameras.
  5. LG G8 ThinQ Front Cameras Replacement: step 5, image 1 of 3 LG G8 ThinQ Front Cameras Replacement: step 5, image 2 of 3 LG G8 ThinQ Front Cameras Replacement: step 5, image 3 of 3
    • Using an opening tool, carefully pry up and remove both cameras from the phone casing.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 18
All Time: 607
