LG G5 Front Panel Assembly
  1. LG G5 Front Panel Assembly, Front Panel Assembly: step 1, image 1 of 2 LG G5 Front Panel Assembly, Front Panel Assembly: step 1, image 2 of 2
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Front Panel Assembly: step 2, image 1 of 3 LG G5 Front Panel Assembly: step 2, image 2 of 3 LG G5 Front Panel Assembly: step 2, image 3 of 3
    • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
    • Press inward with some force to eject the tray.
    • Pull the sim card tray out of the phone.
  3. LG G5 Front Panel Assembly: step 3, image 1 of 2 LG G5 Front Panel Assembly: step 3, image 2 of 2
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
  4. LG G5 Front Panel Assembly: step 4, image 1 of 1
    • Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Pry the glass from the body only a slight amount.
  5. LG G5 Front Panel Assembly: step 5, image 1 of 2 LG G5 Front Panel Assembly: step 5, image 2 of 2
    • Insert the Spudger into the now open space between the body and screen.
    • Push inward to separate the screen even more.
    • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
    • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
  6. LG G5 Front Panel Assembly: step 6, image 1 of 2 LG G5 Front Panel Assembly: step 6, image 2 of 2
    • Peel the Screen away from the body. The two parts should be completely separated.
Joshua Zalmanowitz
1,811 Reputation
4 Guides authored
Cal Poly, Team 18-2, Forte Fall 2016 Member of Cal Poly, Team 18-2, Forte Fall 2016
CPSU-FORTE-F16S18G2
4 Members
15 Guides authored
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 26
All Time: 9,725
