LG G3 Vigor Headphone Jack Replacement
  1. LG G3 Vigor Headphone Jack Replacement, Rear Case: step 1, image 1 of 1
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Headphone Jack Replacement: step 2, image 1 of 1
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Headphone Jack Replacement, Battery: step 3, image 1 of 1
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Headphone Jack Replacement, Midframe: step 4, image 1 of 1
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Headphone Jack Replacement: step 5, image 1 of 3 LG G3 Vigor Headphone Jack Replacement: step 5, image 2 of 3 LG G3 Vigor Headphone Jack Replacement: step 5, image 3 of 3
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Headphone Jack Replacement, Rear Facing Camera: step 6, image 1 of 1
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
  7. LG G3 Vigor Headphone Jack Replacement, Front Facing Camera: step 7, image 1 of 2 LG G3 Vigor Headphone Jack Replacement, Front Facing Camera: step 7, image 2 of 2
    • Remove the front camera.
  8. LG G3 Vigor Headphone Jack Replacement, Motherboard: step 8, image 1 of 1
    • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
  9. LG G3 Vigor Headphone Jack Replacement: step 9, image 1 of 2 LG G3 Vigor Headphone Jack Replacement: step 9, image 2 of 2
    • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
    • The motherboard should now be able to be lifted out of the device.
  10. LG G3 Vigor Headphone Jack Replacement, Headphone Jack: step 10, image 1 of 1
    • Remove the headphone jack by inserting the spudger into the jack and pulling it up and out.
2 other people completed this guide.
Geoff Wacker
91,846 Reputation
89 Guides authored
1 Guide Comment
Works also with D855. There are only a view differences, e.g. screws and a minimal different motherboarddesign.
flux - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 7
All Time: 532
