Shop the Holiday Gift Guide
LG G3 Screen Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
4
Past 30 Days:
5
All Time:
115
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Difficult
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Introduction
Go to step 1 ↓
This guide will show you how to replace a damaged screen on your LG G3.
This part includes the fused display, digitizer and support frame, if your replacement part is the glass digitizer and screen alone, without the frame, follow this longer, more complicated digitizer and LCD replacement guide.
Parts
Tools
    1. LG G3 Screen Replacement, Screen: step 1, image 1 of 2 LG G3 Screen Replacement, Screen: step 1, image 2 of 2
      • Remove the 13 Phillips #00 screws found on the back of the phone.
      • The screw circled in red is shorter than the other 12 screws. For an easier time when reassembling the phone, store it separately from the other screws.
      Ask FixBot
    2. LG G3 Screen Replacement: step 2, image 1 of 2 LG G3 Screen Replacement: step 2, image 2 of 2
      • Locate the same gap used in the earlier step
      • Remove the bottom panel by gently lifting using your fingers
      Ask FixBot
    3. LG G3 Screen Replacement: step 3, image 1 of 1
      • Remove the top panel by gently lifting with your finger
      • Do not pull up too forcefully, as there is a risk of the top panel breaking
      Ask FixBot
    4. LG G3 Screen Replacement: step 4, image 1 of 3 LG G3 Screen Replacement: step 4, image 2 of 3 LG G3 Screen Replacement: step 4, image 3 of 3
      • Take the plastic opening tool and gently wedge it under where the ribbon cable is connected
      • Gently lift up to disconnect the ribbon cable
      • Repeat until all four ribbon cables are disconnected
      Ask FixBot
    5. LG G3 Screen Replacement: step 5, image 1 of 2 LG G3 Screen Replacement: step 5, image 2 of 2
      • Remove the motherboard by lifting gently
      • Take care not to damage the ribbon cables if the other components are functional. Damaging them may result in other components not working
      Ask FixBot
    6. LG G3 Screen Replacement: step 6, image 1 of 2 LG G3 Screen Replacement: step 6, image 2 of 2
      • The following components are kept in place with an adhesive, so it may take some time and effort to get it out
      • Remove the headphone port
      • Remove the vibration motor
      • Remove the rear-facing camera
      • Remove the earpiece speaker
      • If you are going to be using a screen assembly with a pre-installed frame, you may stop here and follow the previous steps in reverse with your new screen assembly. Otherwise, you will now transfer the LCD bezel as well as the speaker grille.
      Ask FixBot
Author
with
Naoto
4,763 Reputation
3 Guides authored
UMass Dartmouth, Team 1-3, Duarte Fall 2014 Member of UMass Dartmouth, Team 1-3, Duarte Fall 2014
UMASSD-DUARTE-F14S1G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 5
All Time: 115
