Introduction
If moisture has entered your LG G Watch, you will need to replace the gasket, and possibly the battery and the motherboard.
Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
Slide the opening pick between the rear case and the rest of the device to separate the two halves.
Gently pull the two halves apart.
The gasket lies embedded in a groove that runs around the perimeter of the front half.
