LG G Watch Battery Replacement
  1. LG G Watch Battery Replacement, Wristband: step 1, image 1 of 1
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. LG G Watch Battery Replacement: step 2, image 1 of 2 LG G Watch Battery Replacement: step 2, image 2 of 2
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
  3. LG G Watch Battery Replacement, Rear Case: step 3, image 1 of 1
    • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
  4. LG G Watch Battery Replacement: step 4, image 1 of 2 LG G Watch Battery Replacement: step 4, image 2 of 2
    • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
    • Gently pull the two halves apart.
  5. LG G Watch Battery Replacement, Battery: step 5, image 1 of 2 LG G Watch Battery Replacement, Battery: step 5, image 2 of 2
  6. LG G Watch Battery Replacement: step 6, image 1 of 2 LG G Watch Battery Replacement: step 6, image 2 of 2
    • Remove the two black Phillips #000 2.5x3mm screws that are located on the right side of the metal clip.
  7. LG G Watch Battery Replacement: step 7, image 1 of 1
    • Use a pair of tweezers to gently lift the metal retaining clip up and out of the way.
  8. LG G Watch Battery Replacement: step 8, image 1 of 2 LG G Watch Battery Replacement: step 8, image 2 of 2
    • Use a spudger to gently pry the battery up from the rear case.
    • The battery is attached with a small amount of adhesive, so some force may be required.
Deja Miller
462 Reputation
3 Guides authored
USF Tampa, Team 2-5, Blackwell Fall 2014 Member of USF Tampa, Team 2-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G5
5 Members
9 Guides authored
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 21
All Time: 8,156
