Introduction
If your watch does not power on after being on the charging station for about an hour the battery needs to be replaced.
First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
Grasp the exposed shoulder with the tweezers to perform the next step.
Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
Remove the two black Phillips #000 2.5x3mm screws that are located on the right side of the metal clip.
There is only one black screw… the other black dot is the reset button extension.
7 other people completed this guide.
4 Comments
Hello where can i buy the battery and the tools to perform this function. Also I love my lg watch and I get 3 days before needing a recharge but, i do not play with it and do not add all the fancy watch faces either. just look at text messages and see who is calling. I think its the best out there only draw back is the cradle charger. please email me. buckeybandit69@gmail.com.
thank you..
where can i but the battery
I know how to change but where can i buy the battery for this watch//
Is there a reason you are removing the straps before the back of the watch? They don't block the back from coming off or really get in the way much.
Andy Wickham - Reply
its in the way, obviously it need to take them off, lol.
silentg4real -
Where can I get this battery?
Josh Wheat - Reply
where can i buy a new replacement rear case? please let me know!
silentg4real - Reply
I'd like to know as well and don't care if it's a knock off either
Joseph Wellman -
