LG G Pad 7.0 Display Assembly Replacement
  1. LG G Pad 7.0 Display Assembly Replacement, Front Panel: step 1, image 1 of 2 LG G Pad 7.0 Display Assembly Replacement, Front Panel: step 1, image 2 of 2
    • The screen assembly is secured to the plastic backing with clips.Insert the plastic opening tool between the screen and plastic.
    • Carefully work your way around the device making sure not to go too deep damaging any eternal components, freeing it from the connecting clips.
    • Be careful around the MicroSD, sim card, power, and volume buttons
    • Lift the tablet from the plastic frame. You may need to loosen some more clips if it is difficult to remove.
  2. LG G Pad 7.0 Display Assembly Replacement, Connectors: step 2, image 1 of 3 LG G Pad 7.0 Display Assembly Replacement, Connectors: step 2, image 2 of 3 LG G Pad 7.0 Display Assembly Replacement, Connectors: step 2, image 3 of 3
    • Remove the red marked connectors by gently prying up. Be sure not to rip the ribbon cables as they are very fragile.
    • You will have to remove the metallic tape near the bottom of the tablet to disconnect the display cable.
    • Remove the three connectors marked in orange by gently prying them upwards. The cables are very fragile so be careful not to rip them.
  3. LG G Pad 7.0 Display Assembly Replacement, Logic Board: step 3, image 1 of 2 LG G Pad 7.0 Display Assembly Replacement, Logic Board: step 3, image 2 of 2
    • Remove the 7 screws marked in red that are securing the logic board to the case.
    • Be sure that all the connectors marked in orange are removed before pulling out the mother board.
    • Very carefully remove the logic board after the screws have been removed
  4. LG G Pad 7.0 Display Assembly Replacement: step 4, image 1 of 3 LG G Pad 7.0 Display Assembly Replacement: step 4, image 2 of 3 LG G Pad 7.0 Display Assembly Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the two screw marked in red.
    • Using the tweezers , gently pull out the metal bracket that holds the charging port in place.
    • Carefully pull out the ribbon connector in orange.
    • Remove the one screw that holds the speaker in place.
    • Slowly pull out the speaker.
  5. LG G Pad 7.0 Display Assembly Replacement: step 5, image 1 of 2 LG G Pad 7.0 Display Assembly Replacement: step 5, image 2 of 2
    • Insert your new mother board with the 7 screws
    • Reconnect all the connectors marked in red back to the mother board.
    • Use a heat gun to loosen the adhesive holding the display to the plastic midframe.
    • Slowly remove the display from the midframe with a razor blade.
    • Use double sided tape to adhere the new display to the plastic frame
echow2001
2,117 Reputation
4 Guides authored
LGBTQ Technicians Member of LGBTQ Technicians
Community
16 Members
53 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 4,919
