LG G Pad 7.0 Battery Replacement
  1. LG G Pad 7.0 Battery Replacement, Front Panel: step 1, image 1 of 2 LG G Pad 7.0 Battery Replacement, Front Panel: step 1, image 2 of 2
    • The screen assembly is secured to the plastic backing with clips. Insert the spudger between the screen and plastic.
    • Work your way around the device, freeing it from the connecting clips.
    • Be careful around the MicroSD, sim card, power, and volume buttons
    • Attempt to lift the tablet from the plastic frame. You may need to loosen some more clips if it is difficult to remove.
  2. LG G Pad 7.0 Battery Replacement, Battery Connector: step 2, image 1 of 3 LG G Pad 7.0 Battery Replacement, Battery Connector: step 2, image 2 of 3 LG G Pad 7.0 Battery Replacement, Battery Connector: step 2, image 3 of 3
    • Remove the battery connector marked in orange, by prying it upwards.You may need some force to do this, be careful not to damage anything.
    • Remove the other connector marked in red by gently prying up. Be sure not to rip the ribbon cables as they are very fragile.
  3. LG G Pad 7.0 Battery Replacement, Battery: step 3, image 1 of 1
    • Gently pry the battery up making sure not to bend it or snag any cables.
    • The battery is secured by two pieces of double sided tape on the left and right edges under the battery.
echow2001
2,117 Reputation
4 Guides authored
LGBTQ Technicians Member of LGBTQ Technicians
Community
15 Members
52 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 27
All Time: 17,358
