LG G Pad 7.0 Battery Replacement
  1. LG G Pad 7.0 Battery Replacement, LG G-Pad 7.0: step 1, image 1 of 1
    • Here it is - LG G-Pad 7.0. Let's dive right in!
  2. LG G Pad 7.0 Battery Replacement, Jumping right into action: step 2, image 1 of 2 LG G Pad 7.0 Battery Replacement, Jumping right into action: step 2, image 2 of 2
    • First things first, use the handy pick iFixit sells on their online store. Carefully pry the frame apart in between the screen assembly an back cover. Be extremely careful, you don't want to damage the motherboard..
  3. LG G Pad 7.0 Battery Replacement, First Glimpse: step 3, image 1 of 1
    • Vuala! We're in! Carefully slide the screen assembly away from the back cover.
  4. LG G Pad 7.0 Battery Replacement, A Look on the Inside: step 4, image 1 of 1
    • Here's the inside of the tablet. Pretty straight forward, nothing to spectacular.
  5. LG G Pad 7.0 Battery Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Grab your * Tweezers, the best tweezers you can get!
  6. LG G Pad 7.0 Battery Replacement, Charging Port Flex: step 6, image 1 of 1
    Buy
    • Carefully pry up the charging port connection from the bottom left with your Tweezers.
  7. LG G Pad 7.0 Battery Replacement, Battery Connection: step 7, image 1 of 1
    • Carefully lift the battery connector.
  8. LG G Pad 7.0 Battery Replacement, Removing the Battery: step 8, image 1 of 1
    iSesamo Opening Tool
    $9.99
    Buy
  9. LG G Pad 7.0 Battery Replacement, Disposal of old Battery: step 9, image 1 of 1
    • After removing the faulty/dead battery, make sure you properly dispose it.
  10. LG G Pad 7.0 Battery Replacement, Don't Forget!: step 10, image 1 of 2 LG G Pad 7.0 Battery Replacement, Don't Forget!: step 10, image 2 of 2
    • After reconnecting the new battery and charging flex cable, make sure you put the headphone jack back into place.
    • There you go! A quick battery replacement on your LG G-Pad.
2 other people completed this guide.
GadgetERService
1,650 Reputation
2 Guides authored
Minnesota Repair Techs Member of Minnesota Repair Techs
Community
3 Members
2 Guides authored
2 Comments
Big thanks to the Author for this, I used it on my v410, worked perfect !
Max Haxster - Reply
My G pad 7.0 wont turn on. Do I have to do some kind or re-boot or restart it? Cause one time when I changed mi iPhone 5c's battery I had to restart it the phone.
Mario Escobar - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 2,681
