Shop the Holiday Gift Guide
LG Front Load Washing Machine Control Panel Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
26
All Time:
230
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Use this guide to replace the control panel in your LG front load washing machine.
Tools
    1. LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: step 1, image 1 of 2 LG Front Load Washing Machine Control Panel Replacement, Safety Precautions: step 1, image 2 of 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Ask FixBot
    1. LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: step 2, image 1 of 3 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: step 2, image 2 of 3 LG Front Load Washing Machine Control Panel Replacement, Unfasten the top panel: step 2, image 3 of 3
      • Remove the screw(s) securing the top panel brackets to the back panel.
      • You don't need to remove the screws securing the brackets to the top panel.
      Ask FixBot
    2. LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: step 3, image 1 of 2 LG Front Load Washing Machine Control Panel Replacement, Remove the top panel: step 3, image 2 of 2
      • Slide the top panel towards the rear of the device to disconnect its clips.
      Ask FixBot
    3. LG Front Load Washing Machine Control Panel Replacement: step 4, image 1 of 2 LG Front Load Washing Machine Control Panel Replacement: step 4, image 2 of 2
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
      Ask FixBot
    1. LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: step 5, image 1 of 2 LG Front Load Washing Machine Control Panel Replacement, Remove the detergent drawer: step 5, image 2 of 2
      • Pull the detergent drawer away from the chassis as far as it will go.
      Ask FixBot
    2. LG Front Load Washing Machine Control Panel Replacement: step 6, image 1 of 3 LG Front Load Washing Machine Control Panel Replacement: step 6, image 2 of 3 LG Front Load Washing Machine Control Panel Replacement: step 6, image 3 of 3
      • Press down on the "Push" button to disengage the clips securing the detergent drawer.
      • Pull the drawer out of its slot on the chassis and remove it.
      Ask FixBot
    1. LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: step 7, image 1 of 3 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: step 7, image 2 of 3 LG Front Load Washing Machine Control Panel Replacement, Disconnect the control panel: step 7, image 3 of 3
      • Disconnect the connectors attached to the control panel.
      • Always grip cables by their connectors and not the wires themselves.
      Ask FixBot
    2. LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: step 8, image 1 of 2 LG Front Load Washing Machine Control Panel Replacement, Unfasten the control panel: step 8, image 2 of 2
      • Remove the screw(s) securing the control panel to the top edge of the chassis.
      Ask FixBot
    3. LG Front Load Washing Machine Control Panel Replacement, Unfasten the detergent dispenser: step 9, image 1 of 1
      • Remove the screw(s) securing the detergent dispenser.
      Ask FixBot
    4. LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: step 10, image 1 of 3 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: step 10, image 2 of 3 LG Front Load Washing Machine Control Panel Replacement, Unclip the control panel: step 10, image 3 of 3
      • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
      Ask FixBot
    5. LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: step 11, image 1 of 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: step 11, image 2 of 3 LG Front Load Washing Machine Control Panel Replacement, Remove the control panel: step 11, image 3 of 3
      • Remove the control panel, making sure to thread any cables through the chassis.
      Ask FixBot
Author
with
Bill Gilbert
41,070 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
1 Guide Comment
other than replacing the control panel is there ways to repair the machine which just dont switch on
ratseaneboy@gmail.com - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 26
All Time: 230
