LG Escape (p870) Loudspeaker Assembly Replacement
  1. LG Escape (p870) Loudspeaker Assembly Replacement, Battery: step 1, image 1 of 2 LG Escape (p870) Loudspeaker Assembly Replacement, Battery: step 1, image 2 of 2
    • Turn the device over and pull the back plastic cover off by inserting your fingernail into the opening at the bottom of the phone and gently pulling.
  2. LG Escape (p870) Loudspeaker Assembly Replacement: step 2, image 1 of 2 LG Escape (p870) Loudspeaker Assembly Replacement: step 2, image 2 of 2
    • With your finger and from the bottom edge, lift the battery out of the phone and set it aside.
    • You now have access to:
    • Your SD card
    • Your SIM card
    • Your device's serial numbers
  3. LG Escape (p870) Loudspeaker Assembly Replacement, Loudspeaker Assembly: step 3, image 1 of 1
    • Remove the 4 Phillips 00 screws securing the speaker assembly to the phone housing.
  4. LG Escape (p870) Loudspeaker Assembly Replacement: step 4, image 1 of 2 LG Escape (p870) Loudspeaker Assembly Replacement: step 4, image 2 of 2
    • Carefully insert a small flathead screwdriver between the speaker assembly and the rear housing
    • Pry the speaker assembly out of the phone and set it aside
Brad
1,908 Reputation
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 316
