Introduction
Most of the LG Cosmos 2 must be disassembled prior to replacing the buttons. Follow these steps to complete this task.
Insert the plastic opener into the slot at the top of the device.
Apply gentle pressure with the plastic tool to pop the back case off.
Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
Use a screwdriver and corresponding bit to remove the four 1mm screws. Set the screws aside.
Pull the ribbon cable through the slit in the keyboard case to separate it from the sliding mechanism.
Use a screwdriver and corresponding bit to remove the four 3mm screws. Set the screws aside.
Use the plastic opener to pry open the front of the phone.
Slip the ribbon cable through the slit to fully separate the two pieces.
Pry the metal piece loose using tweezers or the plastic opener.
Remove the metal piece along with the two ribbon cables.
Flip the front of the phone over and the old option buttons will fall out.
Insert new option buttons.
