Insert the plastic opener into the slot at the top of the device.
Apply gentle pressure with the plastic tool to pop the back case off.
Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case.
Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
