LG CineBeam Fan Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
63
All Time:
1,212
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If the LG Cinebeam's (Model# PH150B) fans aren't working correctly, your projector might overheat and become hot to the touch. This guide will help you replace the fans.
The fans ensure that the projector maintains a constant temperature and prevents overheating. If your projector overheats, it might damage the internals and the battery which could be dangerous.
Before replacing the fans, make sure they aren't working by turning on the projector and check to see if the fans are working or making a sound. If your device heats up and the fans aren't working, you will have to replace them.
You will have to remove the motherboard to access the fans. While removing it, make sure to use caution while replacing the ribbon cables as they could rip.
Before beginning, make sure to power off the projector completely and disconnect from any external power source.
Tools
    1. LG CineBeam Fan Replacement, Bottom Plate: step 1, image 1 of 1
      • Remove three 6 mm screws on the bottom plate with a Phillips #00 screwdriver.
      Ask FixBot
    2. LG CineBeam Fan Replacement: step 2, image 1 of 3 LG CineBeam Fan Replacement: step 2, image 2 of 3 LG CineBeam Fan Replacement: step 2, image 3 of 3
      • Using an iFixit opening tool, pry the bottom plate off of the device and remove it fully.
      Ask FixBot
    1. LG CineBeam Fan Replacement, Motherboard: step 3, image 1 of 3 LG CineBeam Fan Replacement, Motherboard: step 3, image 2 of 3 LG CineBeam Fan Replacement, Motherboard: step 3, image 3 of 3
      • Using an iFixit opening tool, press down the lever on the top of the minilock connector for the speaker and pull the plug out gently.
      • Repeat this process to remove the WiFi/Bluetooth card connector.
      • Remove the battery connector.
      • Remove the fan connectors.
      Ask FixBot
    2. LG CineBeam Fan Replacement: step 4, image 1 of 2 LG CineBeam Fan Replacement: step 4, image 2 of 2
      • Using an iFixit opening tool, pry up the black plastic tabs on the back of the power button/joystick board cable.
      • Gently pull the ribbon cable out of the socket.
      • Repeat this process for the two display cables.
      Ask FixBot
    3. LG CineBeam Fan Replacement: step 5, image 1 of 3 LG CineBeam Fan Replacement: step 5, image 2 of 3 LG CineBeam Fan Replacement: step 5, image 3 of 3
      • Lift the motherboard out of the casing.
      Ask FixBot
    1. LG CineBeam Fan Replacement, Fan: step 6, image 1 of 2 LG CineBeam Fan Replacement, Fan: step 6, image 2 of 2
      • Use your hands to lift the fans out of the projector.
      Ask FixBot
John Dalton
393 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 63
All Time: 1,212
