Installing LG Chocolate Motherboard
  1. Installing LG Chocolate Motherboard, Battery: step 1, image 1 of 2 Installing LG Chocolate Motherboard, Battery: step 1, image 2 of 2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. Installing LG Chocolate Motherboard, Back Cover: step 2, image 1 of 1
    • Use a Phillips #00 screwdriver to unscrew the four Phillips #00 screws on the four corners under the battery to unfasten the back case from the phone.
  3. Installing LG Chocolate Motherboard: step 3, image 1 of 3 Installing LG Chocolate Motherboard: step 3, image 2 of 3 Installing LG Chocolate Motherboard: step 3, image 3 of 3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
  4. Installing LG Chocolate Motherboard, Motherboard: step 4, image 1 of 2 Installing LG Chocolate Motherboard, Motherboard: step 4, image 2 of 2
    • Carefully pry the motherboard off of the back case
Maci Miri
39 Reputation
3 Guides authored
Cal Poly, Team 19-46, Regan Winter 2013 Member of Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Members
22 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 805
