LG Chocolate Camera Replacement
  1. LG Chocolate Camera Replacement, Battery: step 1, image 1 of 2 LG Chocolate Camera Replacement, Battery: step 1, image 2 of 2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Camera Replacement, Back Cover: step 2, image 1 of 1
    • Use a Phillips #00 screwdriver to unscrew the four Phillips #00 screws on the four corners under the battery to unfasten the back case from the phone.
  3. LG Chocolate Camera Replacement: step 3, image 1 of 3 LG Chocolate Camera Replacement: step 3, image 2 of 3 LG Chocolate Camera Replacement: step 3, image 3 of 3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
  4. LG Chocolate Camera Replacement, Sliding Front: step 4, image 1 of 1
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate Camera Replacement: step 5, image 1 of 2 LG Chocolate Camera Replacement: step 5, image 2 of 2
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate Camera Replacement: step 6, image 1 of 2 LG Chocolate Camera Replacement: step 6, image 2 of 2
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate Camera Replacement: step 7, image 1 of 1
    • Pry off the back cover from the front of the case using a plastic opening tool.
  8. LG Chocolate Camera Replacement, Camera: step 8, image 1 of 1
    • Carefully pry the connecting cable between the camera and the motherboard off of the board.
  9. LG Chocolate Camera Replacement: step 9, image 1 of 2 LG Chocolate Camera Replacement: step 9, image 2 of 2
    • Using a small screwdriver, carefully pry the camera out of its position.
    • The camera will seem stuck to the board because of its tape. Don't be afraid to pry it.
Thomas
91 Reputation
4 Guides authored
Cal Poly, Team 19-46, Regan Winter 2013 Member of Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Members
22 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 261
