LG CG225 Motherboard Replacement
  1. LG CG225 Motherboard Replacement, Rear Cover: step 1, image 1 of 1
    • Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
  2. LG CG225 Motherboard Replacement: step 2, image 1 of 1
    • Remove a single Phillips #00 screw from beneath the cover.
  3. LG CG225 Motherboard Replacement: step 3, image 1 of 1
    • Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
  4. LG CG225 Motherboard Replacement, Motherboard: step 4, image 1 of 1
    • Carefully disconnect the gold ribbon cable from the upper right corner of the motherboard.
  5. LG CG225 Motherboard Replacement: step 5, image 1 of 1
    • Using a small plastic opening tool, remove the motherboard.
Darlena
219 Reputation
3 Guides authored
Ohio State, Team 1-2, Buehl Spring 2014 Member of Ohio State, Team 1-2, Buehl Spring 2014
OSU-BUEHL-S14S1G2
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 153
