LG Aristo Screen Replacement
Views: 2K
View statistics:
Past 24 Hours:
Past 7 Days:
23
Past 30 Days:
81
All Time:
2,014
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
The guide was develop to help replace the screen of a LG Aristo, also known as LGMS210 or MS210.
Tools
    1. LG Aristo Screen Replacement, Screen: step 1, image 1 of 1
      • Turn off the device and make sure you are working on a flat, lit surface.
      Ask FixBot
    2. LG Aristo Screen Replacement: step 2, image 1 of 2 LG Aristo Screen Replacement: step 2, image 2 of 2
      • Use an iFixit opening tool to pry off the back case.
      Ask FixBot
    3. LG Aristo Screen Replacement: step 3, image 1 of 3 LG Aristo Screen Replacement: step 3, image 2 of 3 LG Aristo Screen Replacement: step 3, image 3 of 3
      • Remove the SD and SIM cards by sliding the cards out with your finger.
      Ask FixBot
    4. LG Aristo Screen Replacement: step 4, image 1 of 3 LG Aristo Screen Replacement: step 4, image 2 of 3 LG Aristo Screen Replacement: step 4, image 3 of 3
      • Remove the battery by prying it up with a fingernail or opening tool from the bottom edge.
      Ask FixBot
    5. LG Aristo Screen Replacement: step 5, image 1 of 2 LG Aristo Screen Replacement: step 5, image 2 of 2
      • Remove the ten screws from the midframe with a Phillips #000 screwdriver.
      Ask FixBot
    6. LG Aristo Screen Replacement: step 6, image 1 of 2 LG Aristo Screen Replacement: step 6, image 2 of 2
      • Pry up on the screen with a plastic opening tool.
      • Try to avoid using a metal spudger as shown in the images as it has the possibility to damage the screen.
      Ask FixBot
    7. LG Aristo Screen Replacement: step 7, image 1 of 2 LG Aristo Screen Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Detach the cables from the press fit connectors.
      • There are four connectors in total, they consist of two on the cameras, one on the ear jack, and the one attached to the motherboard.
      • You can lift them up with you finger or you can use tweezers (optional).
      Ask FixBot
    8. LG Aristo Screen Replacement: step 8, image 1 of 2 LG Aristo Screen Replacement: step 8, image 2 of 2
      • Gently remove the motherboard.
      Ask FixBot
    9. LG Aristo Screen Replacement: step 9, image 1 of 1
      • Replace the screen.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. I hope that these steps have helped you with your issue.
3 other people completed this guide.
Geobanny Cardenas
199 Reputation
1 Guide authored
Gateway, Team S1-G5, Saknee Fall 2019 Member of Gateway, Team S1-G5, Saknee Fall 2019
GCC-SAKNEE-F19S1G5
4 Members
12 Guides authored
1 Guide Comment
Do i need Loca Glue to replace the outer Glass?
chuck - Reply Share
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 81
All Time: 2,014
