LED Fairy Lights Wire Repair
    1. LED Fairy Lights Wire Repair, LED Fairy Lights Wire Repair: step 1, image 1 of 3 LED Fairy Lights Wire Repair, LED Fairy Lights Wire Repair: step 1, image 2 of 3 LED Fairy Lights Wire Repair, LED Fairy Lights Wire Repair: step 1, image 3 of 3
      • Leave the batteries in the pack and switch the light on.
      • Hold the disconnected wires to the terminals and try to reconnect the circuit.
      • If it isn’t turning on, try switching the wires.
      • Mark one of the wires to differentiate them.
      Ask FixBot
    2. LED Fairy Lights Wire Repair: step 2, image 1 of 1
      • Switch the lights off and remove the batteries.
      Ask FixBot
    3. LED Fairy Lights Wire Repair: step 3, image 1 of 1
      • Cut off the frayed ends of each wire with pliers.
      Ask FixBot
    4. LED Fairy Lights Wire Repair: step 4, image 1 of 1
      • Using a box cutter or wire stripper, strip about ¼ inch of the insulation off each wire's end.
      Ask FixBot
    5. LED Fairy Lights Wire Repair: step 5, image 1 of 1
      • Twist the end of each wire to prepare it for tinning.
      Ask FixBot
    6. LED Fairy Lights Wire Repair: step 6, image 1 of 1
      • Plug in the soldering iron, and wait for it to heat up
      • The soldering iron gets very hot. Leave it on the stand and away from flammable objects.
      • Make sure you are soldering in a well-ventilated area and wearing safety glasses. Check out this guide for more information on soldering.
      Ask FixBot
    7. LED Fairy Lights Wire Repair: step 7, image 1 of 1
      • Hold the solder to the wire to melt it, and apply a small bead to the end of the wire.
      • Repeat for the second wire.
      • Wait for the solder to completely cool.
      Ask FixBot
    8. LED Fairy Lights Wire Repair: step 8, image 1 of 3 LED Fairy Lights Wire Repair: step 8, image 2 of 3 LED Fairy Lights Wire Repair: step 8, image 3 of 3
      • Be sure that the solder is solidified before proceeding.
      • Cut two ½ inch heat shrink tubing sections, and slide it onto each wire.
      • Slide it up as far away from the end of the wire as you can.
      Ask FixBot
    9. LED Fairy Lights Wire Repair: step 9, image 1 of 1
      • Place the wire where you will be soldering it, and use the soldering iron to melt the solder to connect the wire to the battery terminal. Repeat for the second wire.
      • Having another person with you to help hold the wire is helpful!
      • Make sure you know which wire should be connected where. You should repeat the test in Step 1.
      Ask FixBot
    10. LED Fairy Lights Wire Repair: step 10, image 1 of 1
      • Insert batteries and switch on the light to check if it worked.
      • If the light doesn’t turn on, try desoldering the wire, cutting it down, and repeating Steps 4-9.
      Ask FixBot
    11. LED Fairy Lights Wire Repair: step 11, image 1 of 1
      • Remove the batteries. Slide the heat shrink tubing down to the end of the wires.
      • Make sure it covers all exposed wiring.
      Ask FixBot
    12. LED Fairy Lights Wire Repair: step 12, image 1 of 2 LED Fairy Lights Wire Repair: step 12, image 2 of 2
      • Use the soldering iron to apply heat to the heat-shrink tubing, which will make it shrink to fit the wire. Repeat for the second wire.
      • Do not touch any other parts with the soldering iron!
      Ask FixBot
    13. LED Fairy Lights Wire Repair: step 13, image 1 of 1
      • Insert batteries and test if it works. If it does, you’re done!
      Ask FixBot
Enjoy your sparkling lights!
Yessenia Herrera Rojas
1 Reputation
1 Guide authored
UC Davis, Team 2-8, Andersen Winter 2023 Member of UC Davis, Team 2-8, Andersen Winter 2023
UCD-ANDERSEN-W23S2G8
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 13
Past 7 Days: 54
Past 30 Days: 192
All Time: 312
