LED Christmas Lights LED Replacement
  1. LED Christmas Lights LED Replacement, LED: step 1, image 1 of 1
    • 'Getting the faceted "bulb "off. The colored lamp covers snap out- some are pretty stiff but they do come out. They don't unscrew.
  2. LED Christmas Lights LED Replacement: step 2, image 1 of 2 LED Christmas Lights LED Replacement: step 2, image 2 of 2
    • Remove the LED and its plug. In the strands I have, there were two different styles that are not interchangeable.
    • Notice the socket is keyed- it can only go into the socket one way.
  3. LED Christmas Lights LED Replacement: step 3, image 1 of 3 LED Christmas Lights LED Replacement: step 3, image 2 of 3 LED Christmas Lights LED Replacement: step 3, image 3 of 3
    • Remove the bad LED from the plug so you can re-use the plug. Notice the new LED has one leg longer than the other.
    • The long lead goes into the side of the plug with the key as shown in the picture.
    • The bulb of the LED may not seat perfectly but who cares, it will be under the plastic faceted bulb cover.
    • Bend the leads up and cut.
    • Try bulb in your "good" strand if you have one. If it works, put it into your bad strand and see if that has fixed the problem. If not, you know the LED is good now, so go on to the next one.
Betty Lise
650 Reputation
2 Guides authored
Past 24 Hours: 10
Past 7 Days: 37
Past 30 Days: 118
All Time: 76,861
