Kyocera DuraForce Pro Camera Replacement
    1. Kyocera DuraForce Pro Camera Replacement, Camera: step 1, image 1 of 3 Kyocera DuraForce Pro Camera Replacement, Camera: step 1, image 2 of 3 Kyocera DuraForce Pro Camera Replacement, Camera: step 1, image 3 of 3
      • Begin with the phone on its side.
      • Use the plastic opening tool to remove the cover. It is easier to begin near the volume button. The cover should pop off on its own.
      Ask FixBot
    2. Kyocera DuraForce Pro Camera Replacement: step 2, image 1 of 3 Kyocera DuraForce Pro Camera Replacement: step 2, image 2 of 3 Kyocera DuraForce Pro Camera Replacement: step 2, image 3 of 3
      • Remove the 8 screws around the outer portion of the phone with the JIS #0 screwdriver bit.
      • Use the plastic opening tool to remove the backside of the phone.
      • Slide the plastic opening tool under the battery to pry it up and remove it.
      Ask FixBot
    3. Kyocera DuraForce Pro Camera Replacement: step 3, image 1 of 3 Kyocera DuraForce Pro Camera Replacement: step 3, image 2 of 3 Kyocera DuraForce Pro Camera Replacement: step 3, image 3 of 3
      • Once the battery pops out, remove the orange tape that connects the battery to the phone.
      • Next, remove the 2 screws connecting the mounting bracket.
      • Remove mounting bracket.
      Ask FixBot
    4. Kyocera DuraForce Pro Camera Replacement: step 4, image 1 of 2 Kyocera DuraForce Pro Camera Replacement: step 4, image 2 of 2
      • Pull the camera housing out of the phone.
      Ask FixBot
Dylan Ulbricht
735 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 76
All Time: 2,585
