Introduction
If the back panel on your Kurio Xtreme is broken, it may not sufficiently protect internal parts and wires. Follow this easy guide to remove the broken back panel so that you can replace it with a new one.
Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
Carefully lift the back panel off of the rest of the device.
