Kurio Touch 4S Front & Rear Facing Cameras Replacement
  1. Kurio Touch 4S Front & Rear Facing Cameras Replacement, Front & Rear Facing Cameras: step 1, image 1 of 1
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Front & Rear Facing Cameras Replacement: step 2, image 1 of 3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: step 2, image 2 of 3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: step 2, image 3 of 3
    • Remove back cover by prying away from the Kurio.
    • The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
  3. Kurio Touch 4S Front & Rear Facing Cameras Replacement: step 3, image 1 of 3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: step 3, image 2 of 3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: step 3, image 3 of 3
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver.
  4. Kurio Touch 4S Front & Rear Facing Cameras Replacement: step 4, image 1 of 1
    • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
    • All these screws are identical so don't worry if you miss them up.
  5. Kurio Touch 4S Front & Rear Facing Cameras Replacement: step 5, image 1 of 1
    • Remove the battery because it blocks the plastic shield that covers the camera.
    • Do not remove the wires that are attached to the battery and the motherboard.
  6. Kurio Touch 4S Front & Rear Facing Cameras Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the plastic cover that is covering the camera area using tweezers.
  7. Kurio Touch 4S Front & Rear Facing Cameras Replacement: step 7, image 1 of 2 Kurio Touch 4S Front & Rear Facing Cameras Replacement: step 7, image 2 of 2
    • Separate the two halves of your Kurio Touch 4S.
    • Gently use a brush to remove any dirt or finger prints around the area.
    • Use the Tweezers to detach the front and back camera from its place.
  8. Kurio Touch 4S Front & Rear Facing Cameras Replacement: step 8, image 1 of 2 Kurio Touch 4S Front & Rear Facing Cameras Replacement: step 8, image 2 of 2
    • Remove the copper wires by using the Tweezers to replace your new camera.
Khalid AlTamimi
275 Reputation
2 Guides authored
USF Tampa, Team 6-5, Brown Winter 2015 Member of USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 248
