Kurio Motion MotherBoard Replacement
  1. Kurio Motion MotherBoard Replacement, MotherBoard: step 1, image 1 of 1
    • Use the Phillips #0 Screwdriver to remove four 5mm screws from sides of the device.
  2. Kurio Motion MotherBoard Replacement: step 2, image 1 of 1
    • Use the Ifixit opening tool to pry open the device to remove the back of the Kurio Motion.
  3. Kurio Motion MotherBoard Replacement: step 3, image 1 of 1
    • Remove the tape covering the tape from the edges of the battery.
  4. Kurio Motion MotherBoard Replacement: step 4, image 1 of 1
    • Remove the orange connectors that are connected to the motherboard by lifting up the white tab, and then gently pulling the connector out.
  5. Kurio Motion MotherBoard Replacement: step 5, image 1 of 1
    • Take out the 5mm screws located at the top right and left of the motherboard.
  6. Kurio Motion MotherBoard Replacement: step 6, image 1 of 1
    • Remove the tape covering the camera gently.
  7. Kurio Motion MotherBoard Replacement: step 7, image 1 of 1
    • Use your spudger to carefully take out the camera.
  8. Kurio Motion MotherBoard Replacement: step 8, image 1 of 1
    • Use your soldering tool to solder the wires that are connected to the battery and the gray wire next them.
  9. Kurio Motion MotherBoard Replacement: step 9, image 1 of 1
    • Use your soldering tool to solder the wires that are connected to the speakers.
Yazeed Ayyad
447 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 82
