Kurio Motion Audio Jack Replacement
    1. Kurio Motion Audio Jack Replacement, Audio Jack: step 1, image 1 of 2 Kurio Motion Audio Jack Replacement, Audio Jack: step 1, image 2 of 2
      • Use a Phillips #00 Screwdriver to unscrew the four 5mm screws.
      Ask FixBot
    2. Kurio Motion Audio Jack Replacement: step 2, image 1 of 1
      • Use an Ifixit opening tool to seperate the screen from the back.
      • The screen is connected to the back by tabs on the inside of the device. If you pry too hard, they may break.
      Ask FixBot
    3. Kurio Motion Audio Jack Replacement: step 3, image 1 of 1
      • Remove the tape from the edges of the battery and the small piece on the motherboard.
      Ask FixBot
    4. Kurio Motion Audio Jack Replacement: step 4, image 1 of 2 Kurio Motion Audio Jack Replacement: step 4, image 2 of 2
      • Remove the two 5mm screws from the mother board.
      • Remove the connectors by lifting the tabs and pulling gently.
      Ask FixBot
      • Desolder the connections holding the audio jack. To do so, refer to this guide.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 56
All Time: 215
