Kurio 7 Back Panel Replacement
  1. Kurio 7 Back Panel Replacement, Back Panel: step 1, image 1 of 3 Kurio 7 Back Panel Replacement, Back Panel: step 1, image 2 of 3 Kurio 7 Back Panel Replacement, Back Panel: step 1, image 3 of 3
    • Begin by removing the rubber cover from the Kurio 7.
  2. Kurio 7 Back Panel Replacement: step 2, image 1 of 2 Kurio 7 Back Panel Replacement: step 2, image 2 of 2
    • Remove the four 30 mm Phillips #00 screws from the outer case.
  3. Kurio 7 Back Panel Replacement: step 3, image 1 of 2 Kurio 7 Back Panel Replacement: step 3, image 2 of 2
    • Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
    • Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
    • Be careful not to break off the tabs that hold the front cover and the back cover together.
  4. Kurio 7 Back Panel Replacement: step 4, image 1 of 2 Kurio 7 Back Panel Replacement: step 4, image 2 of 2
    • Once all of the tabs are removed, the back cover should come off easily.
    • Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
Eric Rice
913 Reputation
3 Guides authored
Cal Poly, Team 12-36, Maness Spring 2014 Member of Cal Poly, Team 12-36, Maness Spring 2014
CPSU-MANESS-S14S12G36
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 15
All Time: 2,570
