Krups PRO AROMA Coffee Machine X2 470nF Capacitor change
  1. Krups PRO AROMA Coffee Machine X2 470nF Capacitor change, X2 capacitor 470 nF: step 1, image 1 of 2 Krups PRO AROMA Coffee Machine X2 470nF Capacitor change, X2 capacitor 470 nF: step 1, image 2 of 2
    • Perform a visual inspection and electrical test of the unit (damage, etc.).
    • Open the base (4 Phillips screws). Pull off the silicone hoses at the connections to the tank.
    • Now the heater with the hot plate can be pulled out. Loosen the Phillips screw of the electronics holder. Remove the electronics board and detach it from the frame (2 screws).
  2. Krups PRO AROMA Coffee Machine X2 470nF Capacitor change: step 2, image 1 of 2 Krups PRO AROMA Coffee Machine X2 470nF Capacitor change: step 2, image 2 of 2
    • The X2 capacitor (C1, yellow) for the power supply of the electronics (relay, LED etc.) often has a strong capacity loss. As a result, the relay no longer pulls in. Nominal capacity is 470nF, often only approx. 250 nF are left. Unsolder capacitor and replace with new, specified X2 capacitor with 470 nF and 250 V AC.
    • Assemble device and test according to VDE 701/702.
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Hermann Glandorf
209 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 39
All Time: 555
