Korg nanoKONTROL2 Disassembly
    1. Korg nanoKONTROL2 Disassembly, Korg nanoKONTROL2 Disassembly: step 1, image 1 of 3 Korg nanoKONTROL2 Disassembly, Korg nanoKONTROL2 Disassembly: step 1, image 2 of 3 Korg nanoKONTROL2 Disassembly, Korg nanoKONTROL2 Disassembly: step 1, image 3 of 3
      • Start by unplugging, then remove all the faders and knobs, by lifting them up gently.
      Ask FixBot
    2. Korg nanoKONTROL2 Disassembly: step 2, image 1 of 2 Korg nanoKONTROL2 Disassembly: step 2, image 2 of 2
      • Remove the 8 screws on the bottom. Ensure that you have the right screwdriver bit, and that you go slowly and use enough force to turn the screw without stripping it.
      • (Serial numbers and personal info removed from picture)
      Ask FixBot
    3. Korg nanoKONTROL2 Disassembly: step 3, image 1 of 2 Korg nanoKONTROL2 Disassembly: step 3, image 2 of 2
      • After opening back lid, remove 14 screws from inside.
      Ask FixBot
    4. Korg nanoKONTROL2 Disassembly: step 4, image 1 of 3 Korg nanoKONTROL2 Disassembly: step 4, image 2 of 3 Korg nanoKONTROL2 Disassembly: step 4, image 3 of 3
      • You can now remove the main circuit board, lifting out the left side first. (as the mini-USB port may hold the right side in.)
      • The rubber buttons can now easily come out.
      Ask FixBot
    5. Korg nanoKONTROL2 Disassembly: step 5, image 1 of 1
      • Features: (first picture)
      • 8 faders
      • 8 potentiometers
      • 8 x Solo, Mute, Record buttons
      • 5 + 4 transport buttons
      • 2 track buttons
      Ask FixBot
    6. Korg nanoKONTROL2 Disassembly: step 6, image 1 of 2 Korg nanoKONTROL2 Disassembly: step 6, image 2 of 2
      • Chips
      • Labelled with: 2210CFP24V H8S/2210C TH30140 1325
      • ROSON Crystal oscillator, labelled with 24.000F20 HO
      • LW051A 58A04 P256 Texas Instruments Analog multiplexer
      • Mini-usb port
      • Power indicator LED
      Ask FixBot
2 other people completed this guide.
jzohsuh
187 Reputation
1 Guide authored
9 Guide Comments
Hi do you think it’s possible to replace the mini usb port on this, with a usb c connector bought online? I actually have a Korg Nanokey 2 but I think it’s the same setup.
Lemo - Reply Share
Technically yes, but it won’t be easy as the pins are probably in different locations. There are only 4 pins on a USB micro B connector (not in order: Ground, 5V, D+, D-) and there are 24 on a USB C connector (12 different x2). If you have a way of connecting the right pins up then you can use a Dremel or another tool to make the connector fit through the hole if needed.
jzohsuh - Reply Share
Yeah maybe I can solder it via some wires if it doesn’t fit directly. Actually I have zero experience in soldering, but I can get the stuff online, and then bring it to a shop to solder it for me I think. How about this, do you think it’s okay? https://www.aliexpress.com/item/10050014...
Lemo - Reply Share
Also do you think that connector on this page is configured correctly as “host” if I buy the female port? Or I might need a resistor to change the mode similar to what he’s doing on this video? https://www.youtube.com/watch?v=V-vFtiDY...
Lemo - Reply Share
Yes, that aliexpress link could work, provided you make enough space for it. For the resistor, I think it is likely that you'll have to change the mode, but you'll need to check once you've got the part.
I realise this is quite a delayed reply, sorry!
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 80
All Time: 5,056
