Introduction
In this guide, you will learn how to repair and replace a faulty Mode Dial for your Kodak PixPro AZ251. This may be necessary if the camera mode does not change upon turning the Mode Dial, or if the Mode Dial is loose.
Remove a total of four 5mm JIS #000 screws from around the camera:
Two screws from the right side.
Two screws from the left side.
Remove these three JIS #000 screws from the control board:
5mm screw.
4mm screw.
2mm screw.
Remove one 4-mm screw using a J000 screwdriver from the top of the camera, near the mode dial.
