Kodak PixPro AZ251 LCD Screen Replacement
  1. Kodak PixPro AZ251 LCD Screen Replacement, Batteries: step 1, image 1 of 2 Kodak PixPro AZ251 LCD Screen Replacement, Batteries: step 1, image 2 of 2
    • Slide switch to open lock position.
  2. Kodak PixPro AZ251 LCD Screen Replacement: step 2, image 1 of 2 Kodak PixPro AZ251 LCD Screen Replacement: step 2, image 2 of 2
    • Press down on the battery cover and slide outwards to open.
  3. Kodak PixPro AZ251 LCD Screen Replacement: step 3, image 1 of 1
    • Remove the batteries.
  4. Kodak PixPro AZ251 LCD Screen Replacement, Back Cover: step 4, image 1 of 3 Kodak PixPro AZ251 LCD Screen Replacement, Back Cover: step 4, image 2 of 3 Kodak PixPro AZ251 LCD Screen Replacement, Back Cover: step 4, image 3 of 3
    • Remove a total of four 5mm JIS #000 screws from around the camera:
    • Two screws from the right side.
    • Two screws from the left side.
  5. Kodak PixPro AZ251 LCD Screen Replacement: step 5, image 1 of 1
    • Remove the single 5mm Phillips #00 screw from the bottom.
  6. Kodak PixPro AZ251 LCD Screen Replacement: step 6, image 1 of 2 Kodak PixPro AZ251 LCD Screen Replacement: step 6, image 2 of 2
    • Open the flash module.
    • Remove the two 6mm JIS #00 screws found inside of the flash housing.
  7. Kodak PixPro AZ251 LCD Screen Replacement: step 7, image 1 of 3 Kodak PixPro AZ251 LCD Screen Replacement: step 7, image 2 of 3 Kodak PixPro AZ251 LCD Screen Replacement: step 7, image 3 of 3
    • Use a plastic opening tool to pry apart both halves of the camera.
    • Remove the back panel.
  8. Kodak PixPro AZ251 LCD Screen Replacement, LCD Screen: step 8, image 1 of 2 Kodak PixPro AZ251 LCD Screen Replacement, LCD Screen: step 8, image 2 of 2
    • Remove these three JIS #000 screws from the control board:
    • 5mm screw.
    • 4mm screw.
    • 2mm screw.
  9. Kodak PixPro AZ251 LCD Screen Replacement: step 9, image 1 of 1
    • Pull the small metal switch plate to the side.
  10. Kodak PixPro AZ251 LCD Screen Replacement: step 10, image 1 of 2 Kodak PixPro AZ251 LCD Screen Replacement: step 10, image 2 of 2
    • Pry the LCD screen out of the metal housing plate with a plastic opening tool.
  11. Kodak PixPro AZ251 LCD Screen Replacement: step 11, image 1 of 2 Kodak PixPro AZ251 LCD Screen Replacement: step 11, image 2 of 2
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
    • Pull the orange cable out of the socket.
Rachel Llewellyn
509 Reputation
3 Guides authored
USF Tampa, Team S1-G1, Cagle Spring 2018 Member of USF Tampa, Team S1-G1, Cagle Spring 2018
USFT-CAGLE-S18S1G1
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 2,075
