Kodak Easyshare V1003 Lens Replacement
    1. Kodak Easyshare V1003 Lens  Replacement, Battery: step 1, image 1 of 1
      • Turn off camera by firmly pressing the power button that is located on the top of the camera.
      Ask FixBot
    2. Kodak Easyshare V1003 Lens  Replacement: step 2, image 1 of 1
      • Position camera with the bottom facing up.
      Ask FixBot
    3. Kodak Easyshare V1003 Lens  Replacement: step 3, image 1 of 1
      • With your finger, slide the battery cover in the direction of the open arrow.
      Ask FixBot
    4. Kodak Easyshare V1003 Lens  Replacement: step 4, image 1 of 1
      • Lift the battery cover up gently.
      Ask FixBot
    5. Kodak Easyshare V1003 Lens  Replacement: step 5, image 1 of 2 Kodak Easyshare V1003 Lens  Replacement: step 5, image 2 of 2
      • Gently push the battery down until a click is heard. Battery should release and be lifted out of slot.
      Ask FixBot
    1. Kodak Easyshare V1003 Lens  Replacement, Lens: step 6, image 1 of 2 Kodak Easyshare V1003 Lens  Replacement, Lens: step 6, image 2 of 2
      • Use a J00 screwdriver to remove the five exterior screws.
      Ask FixBot
    2. Kodak Easyshare V1003 Lens  Replacement: step 7, image 1 of 1
      • Pull the outer case off using the plastic opening tool.
      Ask FixBot
    3. Kodak Easyshare V1003 Lens  Replacement: step 8, image 1 of 2 Kodak Easyshare V1003 Lens  Replacement: step 8, image 2 of 2
      • Remove the LCD display by unplugging the connector
      • Take apart the LCD display from the back case
      Ask FixBot
    4. Kodak Easyshare V1003 Lens  Replacement: step 9, image 1 of 2 Kodak Easyshare V1003 Lens  Replacement: step 9, image 2 of 2
      • Peel off the yellow film.
      • Peel off the black tape holding the wires.
      Ask FixBot
    5. Kodak Easyshare V1003 Lens  Replacement: step 10, image 1 of 1
      • Unplug the connector by lifting the little lock holding it in place.
      Ask FixBot
    6. Kodak Easyshare V1003 Lens  Replacement: step 11, image 1 of 2 Kodak Easyshare V1003 Lens  Replacement: step 11, image 2 of 2
      • Use a J00 screwdriver to remove two screws located on the far right, near to the main button.
      Ask FixBot
    7. Kodak Easyshare V1003 Lens  Replacement: step 12, image 1 of 3 Kodak Easyshare V1003 Lens  Replacement: step 12, image 2 of 3 Kodak Easyshare V1003 Lens  Replacement: step 12, image 3 of 3
      • Use a J00 screwdriver to remove 6 screws located at the center of the back panel.
      • Gently pull out the lens using you finger tips or pincers.
      Ask FixBot
Sarah Berry
313 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 725
