Easyshare C813 Speaker Replacement
  1. Easyshare C813 Speaker Replacement, Battery: step 1, image 1 of 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Easyshare C813 Speaker Replacement: step 2, image 1 of 3 Easyshare C813 Speaker Replacement: step 2, image 2 of 3 Easyshare C813 Speaker Replacement: step 2, image 3 of 3
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Easyshare C813 Speaker Replacement, Back Cover: step 3, image 1 of 1
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
  4. Easyshare C813 Speaker Replacement: step 4, image 1 of 1
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Easyshare C813 Speaker Replacement: step 5, image 1 of 3 Easyshare C813 Speaker Replacement: step 5, image 2 of 3 Easyshare C813 Speaker Replacement: step 5, image 3 of 3
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Easyshare C813 Speaker Replacement: step 6, image 1 of 3 Easyshare C813 Speaker Replacement: step 6, image 2 of 3 Easyshare C813 Speaker Replacement: step 6, image 3 of 3
    Phillips #00 Screwdriver
    $5.49
    Buy
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Easyshare C813 Speaker Replacement: step 7, image 1 of 3 Easyshare C813 Speaker Replacement: step 7, image 2 of 3 Easyshare C813 Speaker Replacement: step 7, image 3 of 3
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Easyshare C813 Speaker Replacement: step 8, image 1 of 3 Easyshare C813 Speaker Replacement: step 8, image 2 of 3 Easyshare C813 Speaker Replacement: step 8, image 3 of 3
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
  9. Easyshare C813 Speaker Replacement, Front Cover: step 9, image 1 of 2 Easyshare C813 Speaker Replacement, Front Cover: step 9, image 2 of 2
    • Open the battery door.
  10. Easyshare C813 Speaker Replacement: step 10, image 1 of 3 Easyshare C813 Speaker Replacement: step 10, image 2 of 3 Easyshare C813 Speaker Replacement: step 10, image 3 of 3
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
  11. Easyshare C813 Speaker Replacement: step 11, image 1 of 1
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
  12. Easyshare C813 Speaker Replacement, LCD: step 12, image 1 of 3 Easyshare C813 Speaker Replacement, LCD: step 12, image 2 of 3 Easyshare C813 Speaker Replacement, LCD: step 12, image 3 of 3
    • Once the front cover is removed, the battery door maybe closed for convenience.
    • Locate the exposed portion of the LCD screen.
    • Use a wedge to free the LCD screen from the medal housing.
    • Do not pull the screen away completely, it is still attached to the logic board via the yellow cable.
  13. Easyshare C813 Speaker Replacement: step 13, image 1 of 1
    • Remove the screw at the upper right corner of the metal housing.
  14. Easyshare C813 Speaker Replacement: step 14, image 1 of 3 Easyshare C813 Speaker Replacement: step 14, image 2 of 3 Easyshare C813 Speaker Replacement: step 14, image 3 of 3
    • Locate the 2 solder joints holding down the medal housing.
    • Remove the solder.
    • Place wick on solder.
    • Place solder iron on wick
    • The wick should be sandwiched between the iron and the solder.
  15. Easyshare C813 Speaker Replacement: step 15, image 1 of 3 Easyshare C813 Speaker Replacement: step 15, image 2 of 3 Easyshare C813 Speaker Replacement: step 15, image 3 of 3
    • Peel back the black tape from the metal housing.
    • Lift the metal housing from the left so that it hinges on its right side.
    • The metal housing is still loosely attached on its right side.
  16. Easyshare C813 Speaker Replacement: step 16, image 1 of 3 Easyshare C813 Speaker Replacement: step 16, image 2 of 3 Easyshare C813 Speaker Replacement: step 16, image 3 of 3
    • Locate black tab holding the LCD screen connector in the port.
    • Use wedge or fingernail to lift the black tab.
    • Pull the the LCD screen connector out of the port.
  17. Easyshare C813 Speaker Replacement, Logic Board: step 17, image 1 of 1
    • Remove the medal housing from the logic board by carefully peeling the yellow tape off of the metal housing.
  18. Easyshare C813 Speaker Replacement: step 18, image 1 of 3 Easyshare C813 Speaker Replacement: step 18, image 2 of 3 Easyshare C813 Speaker Replacement: step 18, image 3 of 3
    • Locate the 2 screws on the yellow tape.
    • Remove the 2 screws.
    • Remove the yellow tape.
  19. Easyshare C813 Speaker Replacement: step 19, image 1 of 2 Easyshare C813 Speaker Replacement: step 19, image 2 of 2
    • Locate the 2 solder joints near the shutter button.
    • Remove the solder on both joints with the wick and soldering iron in the same manner as Step 11.
  20. Easyshare C813 Speaker Replacement: step 20, image 1 of 3 Easyshare C813 Speaker Replacement: step 20, image 2 of 3 Easyshare C813 Speaker Replacement: step 20, image 3 of 3
    • Turn the camera over.
    • Remove the screw holding the small green board.
    • Lift the small green board.
    • The small green board is still attached to the logic board via wires.
  21. Easyshare C813 Speaker Replacement: step 21, image 1 of 1
    • Desolder the remaining 20 solder joints connecting the logic board to the camera.
  22. Easyshare C813 Speaker Replacement: step 22, image 1 of 2 Easyshare C813 Speaker Replacement: step 22, image 2 of 2
    • Locate the black tab holding the yellow cable in place.
    • Use a plastic opening tool or fingernail to lift the black tab.
    • Pull the yellow cable from the port.
  23. Easyshare C813 Speaker Replacement: step 23, image 1 of 3 Easyshare C813 Speaker Replacement: step 23, image 2 of 3 Easyshare C813 Speaker Replacement: step 23, image 3 of 3
    • Use a plastic opening tool to lift the board from the camera.
    • Continue to remove the board completely.
  24. Easyshare C813 Speaker Replacement, Speaker: step 24, image 1 of 1
    • Carefully pull the red and black wires located on the side of the camera connected to the speaker.
Samantha Murray
269 Reputation
3 Guides authored
Cal Poly, Team 24-22, Regan Spring 2010 Member of Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 Members
20 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 1,804
