Repairing Kodak Easyshare C813 Battery Door
  1. Repairing Kodak Easyshare C813 Battery Door, Battery: step 1, image 1 of 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Repairing Kodak Easyshare C813 Battery Door: step 2, image 1 of 3 Repairing Kodak Easyshare C813 Battery Door: step 2, image 2 of 3 Repairing Kodak Easyshare C813 Battery Door: step 2, image 3 of 3
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Repairing Kodak Easyshare C813 Battery Door, Back Cover: step 3, image 1 of 1
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
  4. Repairing Kodak Easyshare C813 Battery Door: step 4, image 1 of 1
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Repairing Kodak Easyshare C813 Battery Door: step 5, image 1 of 3 Repairing Kodak Easyshare C813 Battery Door: step 5, image 2 of 3 Repairing Kodak Easyshare C813 Battery Door: step 5, image 3 of 3
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Repairing Kodak Easyshare C813 Battery Door: step 6, image 1 of 3 Repairing Kodak Easyshare C813 Battery Door: step 6, image 2 of 3 Repairing Kodak Easyshare C813 Battery Door: step 6, image 3 of 3
    Phillips #00 Screwdriver
    $5.49
    Buy
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Repairing Kodak Easyshare C813 Battery Door: step 7, image 1 of 3 Repairing Kodak Easyshare C813 Battery Door: step 7, image 2 of 3 Repairing Kodak Easyshare C813 Battery Door: step 7, image 3 of 3
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Repairing Kodak Easyshare C813 Battery Door: step 8, image 1 of 3 Repairing Kodak Easyshare C813 Battery Door: step 8, image 2 of 3 Repairing Kodak Easyshare C813 Battery Door: step 8, image 3 of 3
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
  9. Repairing Kodak Easyshare C813 Battery Door, Front Cover: step 9, image 1 of 2 Repairing Kodak Easyshare C813 Battery Door, Front Cover: step 9, image 2 of 2
    • Open the battery door.
  10. Repairing Kodak Easyshare C813 Battery Door: step 10, image 1 of 3 Repairing Kodak Easyshare C813 Battery Door: step 10, image 2 of 3 Repairing Kodak Easyshare C813 Battery Door: step 10, image 3 of 3
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
  11. Repairing Kodak Easyshare C813 Battery Door: step 11, image 1 of 1
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
  12. Repairing Kodak Easyshare C813 Battery Door, Battery Door: step 12, image 1 of 2 Repairing Kodak Easyshare C813 Battery Door, Battery Door: step 12, image 2 of 2
    • Open the battery door by pulling in direction of arrow
  13. Repairing Kodak Easyshare C813 Battery Door: step 13, image 1 of 3 Repairing Kodak Easyshare C813 Battery Door: step 13, image 2 of 3 Repairing Kodak Easyshare C813 Battery Door: step 13, image 3 of 3
    Heavy-Duty Spudger
    Buy
  14. Repairing Kodak Easyshare C813 Battery Door: step 14, image 1 of 3 Repairing Kodak Easyshare C813 Battery Door: step 14, image 2 of 3 Repairing Kodak Easyshare C813 Battery Door: step 14, image 3 of 3
    • The spring is small and easy to lose
    • Carefully remove battery door and spring
    • Make spring is in correct orientation when putting back
    • The spring should hook onto a small hole in the door
Susan Marano
336 Reputation
7 Guides authored
Cal Poly, Team 24-22, Regan Spring 2010 Member of Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 Members
20 Guides authored
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 47
All Time: 12,119
