Installing Kodak EasyShare Z1015 IS Lens Cover
  1. Installing Kodak EasyShare Z1015 IS Lens Cover, Lens Cover: step 1, image 1 of 1
    • Begin by placing the string that is attached to the lens cover underneath the metal bar located on the right side of the camera.
  2. Installing Kodak EasyShare Z1015 IS Lens Cover: step 2, image 1 of 2 Installing Kodak EasyShare Z1015 IS Lens Cover: step 2, image 2 of 2
    • After successfully placing the string through the metal slab, pull the string all the way to the right which will leave enough room to tie the lens cover to the camera.
  3. Installing Kodak EasyShare Z1015 IS Lens Cover: step 3, image 1 of 2 Installing Kodak EasyShare Z1015 IS Lens Cover: step 3, image 2 of 2
    • Next, create a loop with the string and send the lens cover through the loop. This will create a knot to ensure that the lens cover will always remain on the camera.
    • Lastly, pull the lens cover to the right which will tighten the knot. To conclude, simply attach the lens cover to the lens.
Jack
190 Reputation
3 Guides authored
Cal Poly, Team 5-16, Maness Fall 2010 Member of Cal Poly, Team 5-16, Maness Fall 2010
CPSU-MANESS-F10S5G16
4 Members
11 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 3,764
